- Jun 19, 2016
- 7
- 0
I'm experiencing intermittent cancelled alerts on a couple of my cameras. As you can see in the two AI Analysis screenshots, the first analysis typically detects the person, but then the one BI is using thinks the person is static. I'm not sure how BI chooses which analysis to use, but I thought that if any of the analyzed frames contained a person, it would alert. I'm also assuming the asterisk indicates the chosen frame, but I'm not certain there. The time to analyze seems a little high, but I'm not sure if that would have this effect. Any ideas how to improve upon this? I've seen some mention about using "unicorn" in the cancel field, but I want my alerts fired off ASAP.
Thanks!
Thanks!
