AI advice after v6 upgrade
hspindel
Aug 31, 2025
9
USA
Just upgraded to v6. Went very smoothly - thank you Blue Iris.
On the master settings page for AI, I changed the provider from local service on port 32168 to Built-in models. Is that all I need to change to enable the new AI? The button for "Open AI Dashboard" doesn't do anything anymore.
With the old AI, I could open a browser window that showed me what the AI server was doing. Is there a way to do that with the built-in AI? T
The button for "Open AI Dashboard" only works with the external CPAI, there is no web page for the built in AI console! To see what it does on an alert, enable you should be able to <CTRL> double link on any of the alerts that come from AI on the left side of the BI console!
Thank you, Bruce H. I tried control-double-click on one of the left-side It opened a window showing a video clip. That's not what I'm looking for. I want to see (in a text statement) what the AI is determining is present in the video.
When you <Ctrl> double click this what you should see for an alert that was generated using the Internal AI, perhaps you don't have the generate DAT files turned on! Look at the Camera settings on the AI tab, and click on the configure button, make sure that you have the box checked for the "Save AI analysis .DAT files"
