I want to make a surveillance outdoor system.
I'm no expert on Ip cam, I read on your forum a bit of info, so I'll try to put some ideas.
I think every cam at about 200-400€ max each, 3-4 cam if possible. I will use a pc to record and monitor all.
As a detail of IP cams, I'm interested only to see (and detect with some motion/line intrusion detection) some intruders, not facial recognition/identification.
In the map:
I put the distances with google, the blue circles are the point of interest to look more.
I'll put some separate IR to light better on night.
I thought of covering the more space possible with fisheye, for example the new hikvision 4MP DS-2CD2942F in the numbered positions.
Is that model for outdoor?
It seems good in low light.
My doubts are obviously in the distance of vision of that cam.
As you can see in the distances, the cam
1) should get very well the 2 sides of the house, but how is it with the far distant point of about 66m?
2) this one should be in the middle of the first canopy and get 20m for side
3) should get the same 20m of this second canopy and some of the courtyard in front of it
Should this suffice to see some men's silhouette moving outdoor there?
EDIT:
I saw this video of a 4MP fisheye (they put 180° vertically, I will put mine horizontally to get 360°...): it seems to cover well 30m of a basketball court:
even this one covers 30m:
last one I think covers more than 30m:
So, maybe the 1-2-3 points could be covered well, it remains doubts on the distant 66m point...
What should you do here?
In the map:
EDIT:
