JasonS Young grasshopper Mar 9, 2017 54 5 Jersey Shore Mar 11, 2017 #22 fenderman said: How many cams Click to expand... 12 cameras.... maybe Max out at 16 in the future
fenderman Staff member Mar 9, 2014 36,883 21,419 Mar 11, 2017 #23 Jason sokol said: 12 cameras.... maybe Max out at 16 in the future Click to expand... You will need a larger switch or 2 smaller ones. Larger switches have fans and can be very noisy... If noise is an issue, I would use two of these Amazon.com: ZyXEL 8-Port Gigabit Ethernet Smart Managed PoE Switch with 70 Watt Budget - Fanless Design [GS1900-8HP]: Computers & Accessories depending on how you set it up you will get 13-14 cams on them...later you can expand... Reactions: -RJ-, grizfish, jatt and 1 other person
JasonS Young grasshopper Mar 9, 2017 54 5 Jersey Shore Mar 11, 2017 #24 fenderman said: You will need a larger switch or 2 smaller ones. Larger switches have fans and can be very noisy... If noise is an issue, I would use two of these Amazon.com: ZyXEL 8-Port Gigabit Ethernet Smart Managed PoE Switch with 70 Watt Budget - Fanless Design [GS1900-8HP]: Computers & Accessories depending on how you set it up you will get 13-14 cams on them...later you can expand... Click to expand... And if maybe it will go in the attic and a fan will be beneficial, what would you then recommend?
fenderman Staff member Mar 9, 2014 36,883 21,419 Mar 11, 2017 #25 Jason sokol said: And if maybe it will go in the attic and a fan will be beneficial, what would you then recommend? Click to expand... I would not put a switch in the attic...drop the lines into one of the closets in a room.. if you dont mind the noise (im talking very noisy)...then any name brand poe switch will work..look for a managed gigabit model.. Reactions: JasonS
