Hi guys, hoping I can get some guidance on which way to go for my security system. I am the 3rd owner of house that was built in 1999, there is an existing system installed but not operational in our house. It's an Partner P832 system with a PC5010 board. It has all 8 zones configured and a few of them have the wires doubled up. I have no idea which if any of the wires or circuits are good. I would like to get a new security system and was looking at the wireless options but figured I should see what I've got and find out if any of it is worth using or not. If I can fix the existing door sensors that seems like a good option since they are like $25-$30 for the wireless ones. I have included a pic of one of the door sensors which appears that the magnet side maybe missing to me. Also I have picture of what I believe the power supply to be, I put my meter on it and it looked like it was only 4v or so, I cant locate any wires in the alarm bundle that are the red/white combo but perhaps they connect somewhere else.
I am a techie and love my gadgets, I have a handful of Hikvision cameras currently and use my Synology as the NVR.
I like the Honeywell Lynx or DSC Touch but I'm not sold on either yet but would like good integration with other home automation items coming in my future.
I would like to know if there are simple tests I could do to find out which of these sensors are actually working and/or if it's worth it to try and repair since running new wires would be impossible. I guess I would like to know what you think my next steps should be and general advice?
Thank you! James
Thank you! James
