- May 19, 2016
- 11
- 2
Hi
I have an NVR with 20 3MP IP cameras that I want to have display in an application called ActionTiles. It’s a web dashboard for the SmartThings hub.
My NVR supports RTSP streams, but ActionTiles can only handle HTTP streams. I have been using a couple of Raspberry Pi 3 B+ with MotionEyeOS that can get the RTSP stream from my NVR and then make it available as HTTP. It’s good when it works, but it’s incredibly unreliable. I might be asking too much of the RPi’s for my needs, as they frequently hang and have to be rebooted.
The reason for my post is that I think I finally need to invest in Blue Iris.
1. Can I setup Blue Iris to get the RTSP streams from my NVR and have it make them available as HTTP?
2. If so, what kind of system requirements might I need? Would the general BI hardware recommendations still apply when the software is being used this way?
3. If you think I’d be better off replacing the NVR with BI, would you suggest anything different in terms of the PC specs besides additional HD space for the recordings? I’m assuming I would also need to get a PoE switch to power/connect my cameras, and then I would set these up as network cameras in BI?
Thank you in advance!
