@nbstl68
...I don't own a PTZ v2 bro. However, the camera produces such (imo) good output and the PTZ feature allows this camera to serve such a multitude of function (LPR for instance) that I have to recognize it as a very good unit. Yes, there are a lot of failure reports...but sheesh...it's only $150.00 or so. I will definitely be purchasing a PTZ v2 in the future, but I will probably wait for v3 or make certain I get one with the external POE dongle.
Yeah, I was thinking the same thing...I like the design, price and "theoretical" function of the PTZ v2...but I'll wait for a future (who knowswhen)V3 to see if stability, glitch or firmware miracles occur. If they just worked well with good resolution, I'd like to have e them for all my hose cams for max flexibility to change views.
I'm leaning toward fixed turret cams now because of talk about ir reflection of domes I think there are l some mini ptz domes..but would love to find a mini ptz turret if that exists.
Sent from my SM-P900 using Tapatalk
