My parents are moving into a new home and I'm trying to figure out how to set up a wired PoE system for them. They're moving into the Bay Area, which has surprising numbers of break-ins. I know nothing about this subject, but have spent some time browsing these forums looking for advice. The house was built in the early 80s, so it's not wired. I have only seen a few pictures of the outside, but it looks like there should be at least crawlspace above the ceiling since there are vents higher up that I assume are for the space.
I'm looking to spend around $500-700 on equipment and I'll have to see how to get an electrician to come in to run cable, so not sure how much that would cost. I'd like at least one or two of the Dahua 2mp starlight turrets that seem to be really popular. I'd need at least one with the variable focus option so I can zoom in at the choke point for the front door.
The house has a front door facing the street and the back yard is up against a hill. I figured I'd need something good right above the front door and another camera looking out at the drive way into the street. The back of the house has one half that juts out in a strange way, so I may need two cameras back there as well. Inside, there are a couple choke points that I figured I could cover with a single camera.
I don't intend for this to be complete coverage. Just trying to get the high yield stuff and have a visible deterrent. They will continue the home monitoring service that's already installed. And since it's northern California, there are no extremes of weather. There's lots of sun, but it's generally no lower than 40 degrees and no higher than 90 degrees.
