Looking for advice on what cameras to use and placement(s) to monitor a detached garage, driveway, and my postal box located on the other side of a neighbor off the alley. There has been numerous times our mail was stolen/teampered with, before we could get to it.
I will be running an 8 port Cisco POE switch inside the garage. That switch will wire to another switch inside the home. The switch in the home will have the PC/NVR on it, directly. Then a patch into the "primary" switch running the remainder of the network in the home.
All Gigabit connections, switches, etc. Except for the camera itself which all appear to be 100Mb xfer. Saturating the primary network is a concern for me. Using all static IPs for cameras and other components. Inside the house will be a PC/NVR (possibly an FTP server) for storing the video.
Want to keep costs and bandwidth as low as possible (of course) while having enough clarity to identify intruders/offenders.
The camera pointing towards the postal box will need to be of quality to watch someone tampering with mail. The other cameras will be monitoring distances of within 10-20 feet.
There is a door on the back of the house leading to the garage. I want to monitor both doors and the patio slider as best as possible.
All of the proposed camera locales are under eves which have a fairly significant angle to them. The door area between the garage and home could be perfectly flat mounted.
Based on another post I am thinking DS-2CD2332-I for most locations, except near the doors. DS-2CD2132-I in that area.
Sample pics taken with 8MP camera. You will notice our eves are quite large and angled. Good and bad at times. I'd prefer to use dome cameras, if they can be angled properly. But may be forced to use some with arms (bullet) to get a better line-of-sight.
There are other pictures shot at 3MP. As marked.
I took a shot at a rough design. The problem is, without seeing the camera output it's difficult to determine if the camera/placement/angle combination will work.
Any advice welcomed and appreciated. I am thinking HikVision DS-2CD2132-I's, 5 of them mounted in locations as noted. All but maybe the one pointed towards the postal box should be 2.8mm? That means 98 degree view? I get confused on the lens mm's.
Jeff
Jeff
