I'm currently in the process of setting up ethernet cables required to power the 2 cameras. This is my first ever install and have very little knowledge of camera specifications. Though from my own research I am pretty certain I will go with Dahua.
The first camera I need will be positioned within myroof looking down at the road/drive. The picture (attached) was taken using my mobile phone and I am happy with the view/aspect ratio it provides. I have no idea how this translates when deciding on a lens. To be honest I just want both cameras to provide a view similar to what my mobile phone does. Full HD 1920x1080 (16:9) view.
As you can see from the photo attached, the view is quite restricted as it is looking between a narrow gap in the wall of my garage. I held my phone very close to the gap to take the shot, so some suggestions on the type of camera for this would be appreciated. I am really quite unsure about the camera here. Something that allows me to get the lens as close as possible to the face of the wall, looking outside is needed. Obviously night footage isn't going to work with IR as there is no chance of getting IR light outside of the viewing gap.
The second camera I would like to be as low profile as possible. Having something that captures great night footage is an advantage (10M distance max). This camera is going to be positioned from the roof at the entrance of my home looking into my fenced front yard. Again am happy with the angle my phone takes when clicking a picture, so whatever this translates to with lens choice is what I'd like.
I have a home server that runs Ubuntu, so the cams would need to be able to talk to this.
Several cameras that I have in mind are as follows:
IPC-HDBW4830E-AS - small, looks to have good specs. realised this has a dome - possible issues with IR reflection?
IPC-HDW4431C-A - cheap, may suffice
Ultimately I'm after something that is capable of displaying an excellent image. The camera in my roof however has me unsure.
Thanks and look forward to hearing from you.
