Hi to all,
I'm in process of choosing a security system for my house (outer use, covering entrance and terrace), I almost ordered a Reolink system, but then I started browsing this forum, and here I am asking about Dahuas.
After some previous experience with Dahua cameras, I prefer them over Hikvision for example.
Due to budget, I would be going for used components - most likely an entry level Dahua 4 channel Lite NVR4104-P-4KS2.
For cameras, I have 2 options, both used:
1. IPC-HFW2231T-ZS + IPC-HFW8331E-Z (2MP and 3MP)
2. IPC-HDBW4431F-AS *2 (4MP)
Price for both options is similar. For the 1st option, I like the higher FOV, the second option has audio recording (also 4MP) which is nice.
I'd like your advice which option would be better - considering chip, sensor and overall picture quality.
Many thanks!
Many thanks!
