- Feb 22, 2017
- 26
- 6
You need a test rig but probably one in the middle and one on the end, or maybe one centered on each garage door. Something around 6mm, the dahua turrets are popular, hikvision are also decent. Pick your form factor.What would be the best location and camera for the driveway?![]()
I struggled with the same question as do I think a lot of folks. Most end up with one camera trying to do the job of two and fail miserably. The object is to capture with enough detail for facial recognition around your vehicles, not just ID on "a guy in jeans with a black tshirt".
I'm pretty happy with my solution as it gives me good facial ID on either side of the vehicles, and with the Bonus of overview of the street. The right camera of course makes a difference and I chose the Dahua Starlights. Mine are the 3231 HD-CVI version - identical to the IP versions mentioned here in nayr's post. I would recommend the best cameras you can afford for driveway and front door surveillance as this is where 90% of your most important activity is likely to occur.
***Makes sure to choose 1080p playback for these youtube clips
I had a 2012 analog system originally, fortunately I had anticipated equipment upgrades in the future so I ran Cat5 to each location, so in 2015 picked up a Tribrid DVR that allows me to run CVI and/or IP cams. At roughly 1/2 the price with very close to the same performance, I went with CVI cams to start. I may add IP cams where there is a clear benefit/improvement, but so far the 2MP Dahua CVI cams have worked well., Hell they even have 4MP and soon 4K CVI cams out nowRight now I'd like to upgrade one cam to that 5231 IP turret cam as there isn't anything with that form factor with that Starlight quality in the CVI line. I'm just not an IP network guru so the CVI/DVR system has been a good way to still do quality video. I think a lot of "IP network stupid" folks like me have that same networking learning curve.
+1 on that advice!You need a test rig
+1 on that advice!Play around with this, keep PFF 100 or above: Camera Calculator / Design Software
Doing it right!Make a test rig that you can move about and find the best FOV, give it a few days to sink in and ensure your satisfied.. 5g Bucket of Rocks/Sand + 2x4 works well enough, just make sure bad weather wont get to it for those test periods
Where to install turret camera I'm about to purchase?Mount the camera to a long 1x4 or a tripod and try it in a bunch of the locations you're considering. Pay attention to night performance.
Once you've got narrowed down some, evaluate how hard it would be to run the cable / how ugly conduit would look in that location.
Dahua Starlight Varifocal Turret (IPC-HDW5231R-Z)you should pick your locations first w/camera and then run conduit to it; the view you think you have and the view you end up getting are rarely the same until you've done this a few times.. as I was saying in another thread today; a big benifit to DIY installing over hiring a pro is you can take your sweet time.. install locations can make or break a camera, you'd be amazed what a few feet difference can make.
Many tripods won't go as high as cameras are often mounted but they can still be a useful first pass.I will say on test rigs really try to get a tripod, trying to haul a 5 gallon bucket full of rocks and a long piece of wood sticking out is a pain in the ass, lol.
Well, I mean, you might be able to modify one, or use the kind that holds up a big background for taking pictures, they go pretty high, don't remember how highMany tripods won't go as high as cameras are often mounted but they can still be a useful first pass.
There are about 4 locations I'd suggest you try:What would be the best location and camera for the driveway?
Your question seems to indicate a single camera for the driveway. I think you should considered what cameras and views you desire for the entire front of you house. For example, I have wide driveway for a 3 car garage. I installed cams on the opposite ends of the garage with them pointing across each other. Therefore, there's overlapping views and I can see both approaches on my street. Also, I have side yard access on the side opposite of my front door. So for this side access choke point I installed a varifocal to achieve a better facial ID. Lastly, I have a front door cam covering the other side of my house.What would be the best location and camera for the driveway?
