I am about to pull the trigger on some Dahua cams and am leaning towards the Dahua NVR as well. Is there any advantage of using the same brand NVR?
Have any recommendations on Dahua model?YES - functionality and features can be lost if they do not match.
Good to know. Can I run shucked WD drives in these? Also, would you happen to know if the 16 channel version of this model has 16 POE slots?The 5216 model seems to be a fave around here. Get more than you think, so if you plan to run 4 cams, get the 8 cam model. If you plan to run 8, get the 16 cam model. You will probably find that you will want to add cameras and you want to have that capacity.
You would log into the NVR via the NVR IP address and then from the camera screen you will have a web browser that you open to get directly to the camera. So close, just another step or two to get to the camera as the NVR will isolate it from your network IP address.
