looney2ns
Bumping and old thread. Other than the cost of the NVR (which seems almost free with some of the bundled systems when compared to buying everything separately) is there any disadvantage to running BI and an NVR. There are a few reasons I'm considering this.
1. I think my pc is lacking for the cameras I want to use. I'm running 3 4k cameras and BI is running about 60% cpu usage (after optimization)
I don't want the expense of building another PC right now, and I am planning on adding more cameras. I'm running an HP I5 4570 with 16gb ram. and 1TB SSD. My thoughts are not to plan on monitoring all my cameras with BI until I can upgrade my PC
2. I have not found a good solution for viewing my cameras on the television. I think an NVR might work well for this.
3. An NVR would be another backup of my recordings, and would be easier to hide. It would also reside in a completely different part of the house,
therefore increasing the odds of still having my recordings should someone steal my BI computer.
4. Assuming I could use the NVR as a POE switch it would simplify some of my wiring back to my main router / poe switch (not sure it works this way.
would the rest of the network see what's connected to the POE ports on the NVR?. I would think so)
TIA
Study here. Wiki
