Hello
Just been setting up some cameras using Smart PSS which seems user friendly and noticed that you can add the devices using the IP or the serial number or both
I also have a couple of wireless Imou devices which will appear twice in the system if you use the wireless and cable at the same time and if you plug cameras directly
into the NVR they have their own separate separate IP range.
If you turn off the internet the cameras addia via serial go off line but the cameras added by IP remain online so long as you are connected to the same LAN
What strategy does everyone else use for connecting cameras ?
