VLITKOWSKI
works !! i just put "none"Punctuation symbols may be an issue for international installs. To disable custom models you need only enter a non-existent custom model name. Try entering ‘none’ instead of the semicolon.
The :0 disable option is for the default objects and faces model options only.
Excerpt from the help pdf…
thanks
