Hi all,
I have a mostly networking issue I’d love some help with. Part of what I’d like to do is clarify my terminology, so don’t feel bad for correcting it!
We have a multi-home complex of 4 houses and would like to add a camera from a central point visible to all houses, each on their own network. Assume each house has an NVR or DVR connected to their own home router.
I figure I can create a separate network that the cameras hang off, and then bridge that into each network so the cameras are visible on the home networks. Like so:
I’m not sure what I need to consider, but some of my assumptions/questions are:
Is this workable? What things do I need to check and set for each component, roughly? Fibre would be better than wireless for reliability but getting those links installed will be pricier and trickier but I’d consider it if it was going to reduce ongoing annoyance.
Thank you!
Richard
- Is that topography vaguely right or should I e.g. plug the ‘bridge/router’ directly into the DVR/NVR?
- I assume the cameras and ‘camera router’ need to be on their own network.
- I suspect the ’bridge/router’ could be part of the camera network. This way, each home would have a device that is on the camera network
- I should be able to just link the ‘bridge/router’ to the home router, but I’m not sure what settings I’d need on the latter to see cameras on the remote network
- I assume the DVR/NVR’s can record remote IP cameras that are not plugged into them
Thank you!
Richard
