Hello All,
I recently swapped out an IP cam on my Hikvision NVR. The old one was going bad. The new one is the same IP cam/Hikvision. I was able to configure the new cam manually before connecting it to the NVR. I didn't use the existing cam IP, but gave it a new one which was within the NVR list of IP's for cams. The previous cam was plugged into D5 on the NVR. The new cam is connected to D13. This is a 16 port NVR, so lots of extra ports to choose from. Once the NVR was booted up there were issues upon viewing the NVR's IP camera configuration on the web interface.
The cable plugged into D5 was now plugged into D13 for the new IP cam. When viewing the NVR web interface D13 was giving an error message for the new cam Offline (Network Abnormal). Just by chance I took the cable plugged into D13 and put it into D5 and rebooted the NVR. Now I'm able to see the new cam in IVMS and the web interface however D5 is showing Offline, Network Abnormal. D13 is showing Online. This I don't get. Should I have removed the cam from D5 first and then added it to D5 port?
Any suggestions to resolve the Offline, Network Abnormal for D5? This is odd because I have the new Cam plugged into this port (D5) and it's working as expected. And Port D13 shows Online for the cam Status however nothing is plugged into this port.
Thanks in advance.
Thanks in advance.
