Add Axis M7014 to Hik DVR
Sep 25, 2018
4
1
United States
I have an Axis M7014 4 channel video server, and we recently installed some Hikvision NVRs and DVRs.
I have the Axis set up for ONVIF, have a user set up for it, and can get the first camera added to the NVR without a problem (it is a 7616NI).
If I try adding the other cameras, it tells me that I have selected the wrong channel (I tried 2, 3, 4) or that I have already added that IP address if I select channel 1. Have also tried selecting the AXIS protocol with no success.
The Axis has a single IP address for all 4 cameras. Any suggestions?
I suppose I could remove the M7014 altogether and run coax back to the DVR, but that fixes one problem while raising others.
Any new info about this? I have AXIS P7214 and the same problem, only the 1st channel works.
