I've quickly drafted an HTML file that creates ad hoc time-lapses that are controlled with the slider.
It is useful if you need to quickly check some event by skimming thru footage at the same time or date over a certain time period, e.g. it could be useful to quickly see how your garden is growing.
How to use:
1. Edit the HTML file in any text editor and modify the following lines:
2. Save and open the file in any browser
3. Select the camera
4. Select the time range
5. Use the slider to "animate"
How to use:
Code:
var biUrl = 'http://10.10.10.11:81' /URL to your BlueIris server
var cameras = 'Back,Front,FrontDr,Side,Terrace,Doorbell' /List of cameras for the dropdown
var username = '<your BI UI3 username>'
var password = '<your BI UI3 password>'
var atHour = 12 /Time of day (hour) at which the image will be captured
var intervalSeconds = 24 * 60 * 60 /Interval between images, default every 24h
