Subject:
DS-2CD2032 after reset to default, password rejected (recursive)
It involves my new PoE NVR DS-7608 and 3 new cameras. I could not get the .254.1 sub net to ever work. Power is there.
My original, 2 aged IPIR2032 cameras were left with one at default IP and password, and one default +1. I forgot about that and started my project with an IP conflict. Saga evolved from there. .I want to add the 3 new cameras to my home network,The saga has evolved into: all cams needing be reset to default one or more times.; ...usually caused by changing back from the 254 subnet used by the new PoE NVR DS-7608. That task (sometimes) did not go well. I was not using SADP yet.
I did Activate all three new cameras that I intended to add to my iVMS-2000 home network of 2 outdoors cameras.
Using Camera (1 of the 3) I set to default. By now I am convinced that I must be missing something. I am short on foresight and experience! I am convinced that I need to rely more on SADP rather that the NVR for IP and PW changes, but one of the new this camera-1 is not going well this time. Both SADP and my Network scanner verify the default IP indeed was restored... the password is a mystery. (That first got screwed up when I tried changed the IP address using the NVR... not the first time that has happened. I don't know if it was the same camera, as before.)
The SADP user manual says shows the camera to be "inactive", That is => not happening now. It shows "Active" after reset. The IP indeed was reset. Since I can't log in, no image is accesible.
I have twice before made the 7 attempts and got locked out for 30 minutes or more. I am now 4 tries into password try, and now asking for advice and prayers. What to do?
M second "reset camera" pass, I used my Activate password first, then the 12345. My password had a upper case first letter and a number. It was working (on my network) on all three cameras earlier, like when I was struggling with the '254' trials tribulations, so I know the upper case was correct, but I tried lower case, too.
