Acti E32A blue iris settings ?
Total
Jul 1, 2015
22
1
Hello good people : I just received 4 - Acti E32A cameras , have been using Blue iris forever but I can't seem to get the program to connect to the cameras . I don't know what port , or what type of axis camera I need to input to blue iris to connect to the camera . I can connect to the camera problem with the web interface . thanks .
attachment.php
, I'm not sure what camera type to select or what port to
try using generic rtsp from the top of the dropdown and use this as the path..enter 7070 as the rtsp port
[TABLE="class: accesslog"]
[TR="class: odd, bgcolor: #EEEEEE"]
[TD]/onvif-stream1
[/TD]
[/TR]
[/TABLE]
Those settings look right to me, especially if you are getting a picture in BI after hitting OK.
Thanks for the help people. Another question If I have the program ONVIF running on one monitor and watch the same camera in Blue Iris . The image in Blue iris will freeze for 1 second every 8 seconds , but not in ONVIF . Ideas and thanks
