accessing from external network result in 404 not found
dannieboiz
May 13, 2015
508
77
My BI HDD failed last night so I restored the system with Acronis. Everything is back and working as normal locally. I can access the web interface no problem but i tried to access the web interface externally I get the 404 not found error. Blue Iris app works just fine externally. Which means my port forwarding is working as it should.
One thing different that I did have to do was reimporting the registry and register BI algain. I did this yesterday before the crash and it was working but did not capture that backup before it failing. I'm not dead in the water since the app works fine. It's just weird that I can get into the web interface remotely
