I posted a reply, with my issue, in the sticky at the top of this forum "Hitting cameras web pages with a laptop in an NVR with POE" but now realize that I should probably start my own thread to get better visibility... So here is my issue
Interestingly, I can still access the camera's web pages on my laptop but the NVR simply doesn't see the camera (except that it shows that the camera is still drawing power from the PoE port)!
The only way, I have found so far, to get the NVR to recognize the camera again is to do a manual reset of the camera (small button on the back of the camera) which resets the camera to factory settings.
This is an issue for me because of the numerous real power outages in the area where I want to use the NVR/cameras (cottage). Losing full access to the camera, due to a power outage, is a serious problem, not to mention having to manually reset mounted cameras! If the only way to avoid this is to not change any of the camera's settings, then having to accept little control over the camera is also a significant issue! As an example I cannot even change the Day/Night parameters of the camera when I access it through the NVR!
Does anyone else have experience with this?
Here is what I have:
Hikvision NVR (DS-7632N-E2/8P) - a PoE NVR with 8 ports
Hikvision IP camera (DS-2CD2032-1)
After initially setting up the NVR and camera I realized that I had very little control over the camera in terms of setting things like WDR, Digital Noise Reduction...etc. So I was directed to the thread (the sticky at the top of this forum) as a means of accessing the web pages of the camera connected to the PoE NVR. I followed the instructions and I was successful in accessing the camera's web pages and changing the various parameters.
However, I am also testing the capabilities of the NVR and connected cameras to recover from a power outage, and this is where things start to fall apart! From my limited testing, when I pull the plug on the NVR (literally), to simulate a power outage, the system reboots and starts up as I think it should, with full access to the connected cameras... but only if I have not made any changes to the camera through it's web pages (as explained in the sticky thread)! It appears that if I do make changes to the camera then, upon a reboot from the simulated power outage, the NVR cannot find the camera!
