That is a question, not a statement.
I have a dedicated PC in my motorhome that has access via the campground WIFI. The coach's network connects to the CG WIFI via its own router - so any WAN access is essentially double-NAT'ed.
Does anyone know of a simple way to provide WAN access to the BI server w/o port forwarding through both NATs? For example, TeamViewer, which is running on the BI server, can be seen and remotely accessed from any of my devices outside the LAN.
I realize I could use the coach router to set up endpoint-to-endpoint VPN to my home router, but I'm not sure how reliable or stable the CG LAN configuration is (i.e. how often the LAN IP will change, thereby affecting the VPN tunnel). Simple like TeamViewer would be ideal.
The end goal would be to have my home BI server log into the coach BI server and act as an off-site recording backup.
I realize I can TeamViewer into the BI machine and view the console that way - but that's limited in the sense that I can't integrate that into my home BI recording.
