I'm doing LPR from 4 cameras in an office park, and feeding that into the ALPR Database.
I also have 20+ other cameras doing regular monitoring, and my CPU is hovering around 50-60% when there's not a lot of traffic, but during peak traffic times it can peg, especially when the Docker container for the ALPR database starts mishbeving.
I was thinking that offloading some of the AI burden might help. I was running CPAI on the same box as BI, and recently switched to BI 6's built-in AI.
Given that the built-in AI runs on the ONNX runtime, which uses DirectML, which requires only DirectX 12 support, it seems like there should be lots of options.
How much VRAM do I need for LPR? This card is only $50 at amazon, but it's got only 2 GB. For $57 I can get 4 GB. PeteJ has 6 GB:
What's a decent minimum spec for this type of application? Does performance fall of a cliff with insufficient RAM? Or does it degrade gracefully?
Going to 8 GB puts me into far more expensive territory for a science experiment.
Thanks!
For this application, I dont think it matters. I have a RTX3000 (Turing architecture) with 6GB of vram.
Thanks!
