Hi
Just started trialing Blue Iris. I came for the interface, scheduling and Android app.
What I can't find though is how to completely stop BI from decoding the IP camera stream. I just want it written direct to disk. No motion detection, timestamping, nothing. The camera does all that. I am experimenting with a little AMD e450 embedded board with 8GB RAM and an Escam 720p IP camera. Watching the camera with ONVIF Device Manager uses about 35% CPU. Watching a 720p mkv uses about 45% CPU. Watching the camera in the BI UI is about 35%. I have tried to turn off the motion detection and have set the file format as direct to disk. Even running BI as a service, I am still seeing 30% CPU. I figure it is decoding.
I have seen mention on other sites of direct recording using ffmpeg running 2% on similar CPUs. After all, it is just a 4 megabit network stream to disk. Eventually I want to run up to 8 of these cameras. I don't see why this CPU shouldn't be able to do this.
Has anyone had any luck doing this with BI?
Apologies if this has been asked before, I definitely tried searching first.
