- Apr 25, 2018
- 119
- 47
I'm on a budget so am starting with only 2-3 cameras. Am hoping to get some guidance from you good folk out there on essentials I MUST HAVE to do the install. I admit I was a bit naive about all this IP camera stuff - I thought I'd just buy the camera and a few other items and that was done - but it all seems to be adding up, and I'm hoping that you can help me separate the wheat from the chaff.
In essence, I don't need the highest price products and am happy to spend less if it's still a decent product, and or I don't want to buy tools that I won't need after I finish these installs.
The cameras will be installed on soffits (which are made of wood) and on wood ceilings.
I don't know if mounts are needed, or if Andy ships those direct, or do I just make do (not sure yet? - Any advice?
Things I already have or are on order:
1. Cams from EmpiretechAndy (appreciate service there) - I can see why this can be addictive
2. Ordered outdoor/CMX cable - General Cables brand solid copper CAT5E UTP - will arrive in a week
3. Duct seal
4. Scotch Linerless Rubber Splicing Tape 130C, 3/4" Width
5. Scotch Super 33+ Vinyl Electrical Tape, 3/4 in
Plan to buy
1. Crimper - Klein Tools VDV226-107 Compact Ratcheting Modular Crimper ? Or maybe a cheaper one if I only have 2-3 cameras?
2. RJ45 connectors
3. A computer to run BI
4. BI software
5. Will need POE switch
Thinking of:
1. Running Wire tool like https://www.amazon.com/Fiberglass-R...ocphy=9059806&hvtargid=pla-362775615011&psc=1 or the Klein Tools one might be better: https://www.amazon.com/25-Foot-Meas...G37KC7A5TCQ&psc=1&refRID=PYTHNPXPBG37KC7A5TCQ
2. Cable tester [ a cheapo]
Do I need:
1. Gang wall plate and keystone plate?
Anything else that you would deem essential?
I've read the wiki and done search posts; there is a wealth of information and very valuable, and would appreciate your guidance per above. The search posts have sometimes varied in the recommendations and some tools are beyond my requirements (budget and need)
Thanks folks
3. Duct seal
Plan to buy
2. RJ45 connectors
4. BI software
Thinking of:
Do I need:
Thanks folks
