- Dec 24, 2016
- 410
- 320
Hey all,
I'm working on developing an integration between my Abode security system and Blue Iris.
Abode does support reporting alarms via IFTT APIs. This could be used to send a web request to my Blue Iris machine to trigger some action. I'm not a big fan of relying on cloud APIs for something like this, however.
Abode (like SmartThings and other home automation systems) has the ability to toggle Z-wave switches on events. I've configured my Abode alarm to toggle a Z-wave relay (GoControl Z-Wave Isolated Contact Fixture Module - FS20Z-1 - Connected Home Modules - Amazon.com) when the alarm goes off.
I'm going to use an Arduino to act as a means of relaying multiple inputs to a COM port on my Windows machine.
I'm writing a Java application which will monitor the arduino and when it reports the alarm has triggered, it will use the Blue Iris web API to grab an image from all of the cameras in my system and then email it to me.
Some other extensions to this I'd like to make:
- Use another GoControl relay which Abode will turn on whenever the alarm is armed.
- When the alarm is armed, I'll switch Blue Iris to a different profile which would cause 24/7 and motion based recording to start on my my the two Samsung wireless ipcams I've got linked into Blue Iris (I don't really want to record 24/7 in the house when I'm home).
