Strange issue for sure.
LOCO-M5 in bridge mode/AP Tested on 3 different routers and 2 switches AND WORKS FINE. No connectivity issue, static IP
Linksys EA7500 will NOT even see the LOCO..Period, no ping NADA, Does anybody know if I need to set or disable security feature on this router to make it see the loco.
I have already defaulted the router, put it on my network, works fine with all devices. If I plug the LOCO into a 10/100 switch, then the plug it into the router, it see's it.
I manually added it to the reserve by Mac and still no beans on the EA7500.
Works fine on my asus router and two older routers I have hanging around, so all connections and cables are good before you ask.
I had another M5 Loco and fired it up, same issue.
Here is a link from another form, my issue is pretty much the same issue.
Nanostation Loco 2 & Linksys EA7500 router | Ubiquiti Community
