- Aug 11, 2016
- 95
- 8
First off I am a newby to the technical side of the camera world. I have been installing them for years for a company but don't do much past just that.
I am new to this NVR. I have only worked with servers for cameras in the past. A couple question if I may.
http://www.hikvision.com/UploadFile/image/2013052208524985525.pdf
1. Am I correct in assuming that the two LAN ports on this NVR can be used to connect POE switch's? I guess it just stops you at 32 cameras?
2. Can I get two monitors to run simultaneously? I have a spot monitor I need to run and loop four camera feeds to. I also have a monitor that will show all the cameras (17-24 cameras so far). For the second monitor I can't use a PC with the VMS software it has to be a monitor. I was thinking HDMI for one and VGA for the second unless there are distance issues. Both monitors are roughly 120 ft. away from the NVR.
3. I called Hikvision and voiced my concern about bandwidth issues. The highest upload speed we can get here is 12K. They said I should be ok ....... These cameras are all 3 & 4 meg. Seems that if I have three or four people accessing these at the same time I may have an issue. Your thoughts?
Thank you for any insight. I have to install this system pretty soon.
Brian
Brian
