- Jan 7, 2015
- 3
- 0
Greetings,
I am having problem adding the 9th camera to the NVR. What I have done is connecting #8 and #9 cameras to a POE switch and then connect POE switch to NVR's port-8. I then manually add #8 and #9 cameras into NVR, as they are not detectable. NVR is able to connect with #8 but #9 is "not reachable". I know both cameras are working when each is directly connected. That makes me believe the issue is at the NVR side?
How I add camera is per the prompt -- typing in IP address, choose HIKVISION camera, Channel 1, user and password. (Typing these using my memory as I am not in front of NVR at the moment)
Greatly appreciate expert's advice on:
1) What others areas shall I look into?
2) Shall all cameras use fixed IP or DHCP?
