I have a motion sensor in the corner of a wall & ceiling that I want to replace with a PoE camera. See attached image. Hopefully the next couple of weeks I will open the wall and pull some Ethernet cable to that location (same place where the other cable for the motion sensor is currently coming out). The camera should be covering an angle of 90 degrees. There will be some low dimmed lights on all the time about 30 feet away. Ideally, the camera has some built-in IR light that can reach at least 30 feet. The sole purpose of the camera is to have motion detection (used for home automation and for security to detect motion) and to see where our dog is. There is no intention to use this for face recognition or anything like that. It will be used with BlueIris. What camera would you recommend for something like that?
