IPCT 8 MP(4K) IR Fixed Dome Network Camera, 2.8mm
Mike
Staff member
Mar 9, 2014
3,040
3,047
New York
This 8MP (4K) fixed dome has a 2.8mm lens and amazing 8MP / 4K resolution.
  • 8 MP(4K) IR Fixed Dome Network Camera (POE, 2.8mm lens)
  • H.265, H.265+, H.264+, H.264
  • DC12V & PoE (802.3af) , 3D Digital Noise Reduction
  • On-board MicroSD storage, IP67 weatherproof, 30m IR range
  • Backed by IP Cam Talk, over 65,000 users worldwide!
Tech Specs
  • Up to 8 megapixel high resolution Max. 3840 20 @ 2160 fps
  • 2.8 fixed lens
  • H.265, H.265+, H.264+, H.264 20dB
  • Wide Dynamic Range / 3D Digital Noise Reduction
  • IR range: 30m
  • Supports on-board storage, up to 128
  • IP67, IK10
  • Image Sensor: 1/2.5" Progressive Scan CMOS
  • Signal System: PAL/NTSC
  • Min. Illumination: Color: 0.01 Lux @ (F1.2, AGC ON), 0.028 Lux @ (F2.0, AGC ON), 0 Lux with IR
  • Shutter time: 1/3 s to 1/100,000 s
  • Slow shutter: Yes
  • Lens: 2.8 mm, horizontal field of view: 102°
  • Lens Mount: M12
  • 3-Axis Adjustment: Pan: 0° to 355° , tilt: 0° to 75°, rotate: 0° to 355°
  • Day& Night: IR cut filter with auto switch
  • Wide Dynamic Range: 120 dB
  • Digital noise reduction: 3D DNR
  • Focus: Fixed
Smart Feature-set
  • Behavior Analysis: Line crossing detection, intrusion detection
  • Line Crossing Detection: Cross a pre-defined virtual line
  • Intrusion Detection: Enter and loiter in a pre-defined virtual region
  • Recognition: Face Detection
More information available by clicking here.
Reactions: Dasstrum
