unless otherwise specified, I would assume it's in the 850nm range, like most IR-equipped cams.
This means there will most likely be some visible red glow from the IR's...
there are some IR iluminators that have 940nm-centered IR, but that's much less effective unless the camera's sensor is specifically designed for it...
