6.0.9.0 I would tell you what is new but...
Tinman
1,763
2,354
USA
I assume we have to find out ourselves. :lmao:
I really have to wonder what their release process is, considering how often it comes out without any change log or notes. It could be a simple matter of their cloudflare proxy not having caching configured properly for the changelog URL too. But the smart money is on it being human error during a manual release process, forgetting to update the release notes.
He included UI3-332 at least. So ... you can have UI3's change log I guess. :lmao:
Version 332​
  • Added Check for Updates button to UI Settings > Server Control based on a proposed updatecheck API which is not currently implemented in Blue Iris. Includes automatic fallback to a much simpler update checking interface and a link to the API proposal and documentation.
Version 331​
  • Password input fields should now all have a button to make the password visible.
  • Fixed a bug where using the "Apply" button to change a profile name caused future attempts to change the name to fail until the profile editor was closed and reopened.
Login page version 35​
  • The "user" and "pw" URL parameters are now read by login.htm if they exist and credentials are not already saved.
The ball is in their court for implementing the update check API that will allow UI3's new manual update check capability to function. If/when Ken implements that in Blue Iris, UI3 will begin giving you a clone of the Blue Iris News and Updates panel from the local console. It'll be particularly helpful for anyone who (like me) uses UI3 for remote access and finds it cumbersome to log in with remote desktop or equivalent.
Don't forget that quite frequently the update released on their website isn't what it claims to be!
  • Sad
Reactions: gwminor48
I very much agree. HTML is generally more accessible, lighter-weight, and it is very easy to produce automatically assuming the source is markdown or something.
Look what happens when you copy and paste directly out of the PDF!
[6.0.1.20] – 2026-1-20Fixed• An issue introduced in 6.0.1.16 where pre-trigger image objects may not have beenmarked as static• On Settings/AI the server address will be automatically parsed to remove protocolspecifier and place the port number into the port box.• An issue where a camera selection for features of several action set actions (suchas email, include an image from another camera) will alter the behavior of &NAMEand other camera-specific macros.• An issue where the static/periodic scan was not giving enough weight to similarcategory objects such as car/truck, which the detection often confuses inlow-confidence scenarios.Added• Experimentation with a replacement ALPR OCR ONNX. If this file is found in theAI/models folder it will be used in place of the initially installed module:
Or if I paste into a text editor first, it at least preserves line breaks better but does not keep bold text or other formatting. Also it has hard line breaks wherever text was wrapped in the PDF, but it is better than what you see above where words are just jammed together like protocolspecifier when the line breaks were all lost.
Fixed
marked as static
Added
t_s_v1_global.onnx
But compare that to copying release notes from a github page where the release notes are rendered as HTML. Most formatting, links, and list nesting is preserved.
Version 332​
Version 331​
Version 326​
  • Added some additional context menu functionality to help UI extension authors modify UI3's context menus.
    • For now, only video player context menus are supported via new custom events "BeforeRegisterCanvasContextMenuLive", "BeforeRegisterCanvasContextMenuRecord", "BeforeRegisterCanvasContextMenuTimeline".
    • Simplified context menu item enabled/disabled state changes (hopefully correctly) in order to better support menu items added by UI extensions.
    • Modified jquery.contextmenu library so the applyrule method no longer uses the name field on each rule; it was adding unnecessary complexity for me.
    • Example Local Overrides Sample: Local Overrides Sample: Add Context Menu Button "Pause Schedule".
Version 325​
  • MP4 clips can now be opened in a new browser tab. Upon first use, the user is asked whether to "Open in UI3" or "Open in Browser Tab" and given the option to not ask again.
  • Added "Toggle Flag" hotkey, unset by default.
  • Added keybind for closing the topmost dialog, bound to the escape key.
  • Hotkeys can now be used while dialogs are open if they have a property allowInDialogs: true.
  • Fixed bug where dialogs could not be brought to the front of the display order by clicking their title bar (required clicking their body).
The release process has been revised to prevent specific development environment folders from being copied into releases, wasting space (affected UI3-323 and UI3-324).
Reactions: CrazyAsYou
@bp2008 Speaking of updating Blue Iris via UI3, unless you fixed this already, it has a bug where it shows the latest version available and provides an update button even if the Blue Iris subscription is expired. Hitting the update button causes it to update anyway (something that's grayed out in Blue Iris), putting Blue Iris in demo mode. Rolling back to the last supported version is not easy.
I've been aware of that issue for some time, with fixes proposed to Ken since about 14 months ago when the update notification was implemented originally. What it boils down to is that all UI3 is told is that version "6.0.9.0" or whatever is available. No notice of whether installing the update will cause BI to enter demo mode. I believe it did get resolved more or less in a more recent Blue Iris release a few months ago now but if you're on an older Blue Iris version then you won't have the fix. You can at least disable the update notice in UI3's settings if it is annoying.
Reactions: Techie007L
We have the 6.0.9.0 change log now!
[6.0.9.0] – 2026-7-6Fixed• Legacy AI facial recognition “No face found in image” messages were causingconfirmed alerts in some cases• The “remove item from convert/export queue” clips list right-click option was notalways functional• Clip list actions on timeline records did not result in a clip list updateChanged• UI3 updated to 332Added• Highly improved PTZ AI tracking by adding velocity/position estimation
Oh damn it.
Fixed
always functional
Changed
Added
And 6.0.9.1 is:
[6.0.9.1] – 2026-7-10
Fixed
• Issues with legacy AI providers not associating face/plate objects with parent
objects and not propagating coordinates for saving these images
• Empty folders are now removed in the AI\faces folder
• A bug with action set Run actions containing \n in the path
Changed
• Hardware decoding flow to assist in prevention of memory leaking by some versions
of the Intel drivers
• Removed a 60-second timer used to prevent back-to-back OnLogin action sets.
Now each Login shown in the Status/Log will result in the execution of the user’s
OnLogin action set.
Added
• ONVIF events may now be shared with multiple cameras set to the same IP: port.
Rather than having each camera on a DVR open its own events subscription, enable
“Get ONVIF events” on only one of them and that one will share with the others.
Otherwise, the DVR may offer a limited number of events subscriptions, leaving
some cameras in error conditions. Each camera is differentiated by its “source”
values set on the bottom of the network camera configuration window.
