6.0.3.1 - Broke my webserver
Nov 9, 2016
1,826
1,981
SF Bay Area
Just a heads up. All tested customizations using HTTP Interface and JSON Interface calls are not working.
I haven't taken time yet to debug this. I just reverted to 6.0.2.10.
(and yes I did reboot the server after updating)
Reactions: jrbeddow
Please elaborate: how many things will likely be broken by this? Pushover notifications as well?
Can I presume you have sent off a support request to Ken?
This is new "security" features noted in the changelog.
Most likely you are getting hit by the "User-Agent" string validation which by default will block anything that does not pretend well enough to be a normal web browser.
I already sent Ken a support request asking to skip those new validation functions for local/LAN addresses as that should resolve the majority of 3rd-party integration issues. But unless Ken walks back this entire set of security features, you can expect it to continue causing pain when accessing via an address which Blue Iris does not recognize as local.
I did not test the Pushover curl Action before reverting back to 6.0.2.10.
But based on bp2008's comments, I doubt it's affected as it does not involve BI HTTP or JSON commands.
Pushover notifications still work. I also got the webserver to work by adding my external IP address to the "Limit access by IP address:" field.
