This camera has been working for about 6 months. I had the system shut down for a couple weeks while I was busy with other things. When I started it back up the 5442T-ZE didn't connect with Blue Iris. The other camera on my system is working fine (T2231T-zS).
I didn't touch any wiring or make any changes to anything.
I brought the cameras inside and connected it to my hub with a different cable and got the same result:
When I try to connect directly by putting the IP address in the browser address bar I get a message saying it can't be found.
I used the Dahua IP Config tool and it was able to find the camera's IP address, which was the same as I was using.
So what should I do at this point? Any suggestions?
