Hi, I’m looking to replace my current 5442-ZE with something better for face recognition and possibly license plates on mostly static cars at about 60 ft. Even at max 12 mm zoom, the image is still too wide (I’m capturing the side wall and the other side of the street), so I feel like something around 20+ mm could still give me enough overview while improving identification quality.
With the 5442-ZE, faces and plates are sometimes readable, so I’m thinking a Z4E-type lens might be enough, while a Z12E could end up being too narrow for my needs.
I’ve also been looking at ANPR options like the Amcrest IP4M-1072EW and Dahua ITC413-PW4D-Z3, but I’m not sure they make sense as a “do-it-all” camera. i don't want a visible IR, the Dahua lists 730 nm illuminators, while the Amcrest specs seem a bit confusing between 730 and 850 nm.
1. Are these two ANPR cameras essentially the same, and does anyone know for sure if the Amcrest uses 730 nm or 850 nm IR?
2. Do any of these support something like auto/active zoom, or at least ONVIF zoom controls/presets that could be triggered via HA/Frigate automations?
3. If that’s possible, is the zoom/focus speed any better than the 5442-ZE, or are Z4E, Z12E, and ANPR models all about the same in real use (set and forget)?
Dahua:
Amcrest:
Dahua:
Amcrest:
