5442-ZE-S3 lawn mower tripwire false alarms
lukeeper
Jul 18, 2023
26
10
Poland
Hey!
I am trying (with no luck) to get rid of false alarms generated by lawn mover crossing my tripwire or entering itruson zone. It is generating "human" alarm. Changing sensitivity doesn't work. I was trying to setup Expirience database but when I am trying to import video there is "No data available" message. Can someone assist me? No luck with both acupick enabled and disabled. Effective Target - only human is set as "on".
Is a human driving or pushing the lawnmower?
Acupick for most residential users is a waste of time and consumes resources.
Are you running IVS or VMD?
Reactions: RyanB
YES, AcuPick / IVS with VMD is creating a lot of false positives on 5442-S3..
They are limited by SOC / AI performance...
You can disable AcuPick and try only IVS with Large AI models enabled...
or You can increase minimum object size for both IVS and VMD to be bigger than lawnmower..
