If those are wireless access points meant for Internet access then no, it is not recommended to allow cameras to have access to the Internet.Do you have your Cameras on the same POE as your access points?
Ideally they would be on their own isolated subnet, apart from the Internet.
No, that sounds good, provides the same protection.I have them on a separate VLAN that is not allowed to talk to the rest of the system, I can only talk to them. I am utilizing a Unifi system; is this not advisable?
POE switches aren't that expensive. I went overkill on mine. Why buy a bunch of nice cameras and cheap out on the switch?
Are your 5442s running IR at night or are they in color. Running with IR on is about 7.2W, 2.6W without IR.
