5442 old or new : change default web settings timeout?
rdxny
Pulling my weight
Oct 15, 2022
255
206
ny
on the Dahua 5442 web settings (either older version or new s3 version), the timeout before having to re login is short. Can that be changed? I see no way... when working on several cams it's a pain to have to re login constantly.. and no way to use a password saver either I think?.... thanks
That problem exists with all of my cameras, but I think the NVR is the problem with the short timeouts. I sure would like for no timeouts to occur unless I am the one requesting it. . :banghead:
Reactions: JDreaming
That problem exists with all of my cameras, but I think the NVR is the problem with the short timeouts. I sure would like for no timeouts to occur unless I am the one requesting it. :banghead:
I'm using BI, no NVR, so the short timeout is from the cameras I think...
I use the NVR Web Login and sometimes open multiple camera through that program when adjusting settings. The NVR Web Login and any cameras I have open through it all require a re-login at the same time. Whatever causes that to occur sure is irritating.
