5.9.2 - May 29, 2024
fenderman
Staff member
Mar 9, 2014
36,883
21,419
It’s now possible to trim/export to the BVR format via the viewer window or when
exporting alerts using the Alert tab option. Several alert timing and export inconsistencies
and bugs have been smoothed-out during this development.
A “clip info” dialog is now available in the viewer when you right-click on an open BVR file.
Today this provides basic encoding information, but will be expanded to offer more
extensive analysis
Update 5.9.2.1
Two minor updates:
1. Ken just updated the 'Find in clips' dialog for the 'search-in -clips' feature (click the magnifying glass icon while playing a clip). Now you can select the Profile for the motion settings to be used.
2. The JSON clipstats command has a new parameter triggeroffset ... like offset, but the offset of the actual trigger, not the alert playback offset.
The difference between the two (triggeroffset - offset) is the 'Pre-trigger playback time' (Camera settings > Record tab) that was in effect at trigger time.
