5.8.8 - March 4, 2024
mvoss
Joined
Oct 21, 2023
Messages
25
Reaction score
29
Location
Texas
How about you remove the cutom models from the folder you don't need. I've always done that. That should work, correct?
VideoDad
Pulling my weight
Joined
Apr 13, 2022
Messages
164
Reaction score
220
Location
USA
I wish Ken would fully clear this up.
I have most cameras using "ipcam-general" , some using "ipcam-combined", one using "license-plate" and one using "delivery". I just want to make sure that they aren't going to start using all 4 on all cameras since I've specified the model I want to use for each camera. So is this behavior changed now, and if so why?
Some cameras stop as soon as they've found an object, others keep going because I have some non-existent object specified in the "to cancel" field. Again, is this behavior changed and if so why?
I don't usually update unless it's necessary, so I'm definitely holding off. But at some point if I do, I need to know if/how this is changing.
looney2ns
Joined
Sep 25, 2016
Messages
15,720
Reaction score
23,065
Location
Evansville, In. USA
Email him and ask.
jrbeddow
Getting comfortable
Joined
Oct 26, 2021
Messages
380
Reaction score
490
Location
USA
Can't answer the "why" part, but this change occured with 5.8.7.8, see below:
wittaj
Joined
Apr 28, 2019
Messages
25,516
Reaction score
49,781
Location
USA
Sadly this feature didn't improve my image for selection and I need to keep a dummy object in the to cancel.
jrbeddow
Getting comfortable
Joined
Oct 26, 2021
Messages
380
Reaction score
490
Location
USA
Hmm...I'm surprised that is still working: from the sounds of that 5.8.7.8 write-up it shouldn't actually add any additional analysis by doing so. Strange that you can still "force" the added images.
Perhaps what happens in your case is that the "best" image occurs towards the end of a long string of consecutive analyses.
wittaj
Joined
Apr 28, 2019
Messages
25,516
Reaction score
49,781
Location
USA
Yeah it is one I use to get a car in the center of the alert image at night. Without it I continue to get just the front or back of the car and sometimes just barely the head or tail lights LOL
Tinman
Joined
Nov 2, 2015
Messages
1,228
Reaction score
1,529
Location
USA
Well, decided to give 5.8.8.8 a go since there has been no update for a few days. So far 15 hrs in and not one error and no restarts of BI service. Also, My AI settings are the same as they have been for a year or so and it is working perfect. Not sure if this was in help file before or not but Ken added a few examples.
So on my settings below it is working as expected.
quest100
Pulling my weight
Joined
Aug 10, 2018
Messages
150
Reaction score
224
Location
CA
For those that grab updates just because (as I do because I'm not quite so worried about bad things happening around here that I'd miss footage of), and I enjoy checking out the new changes. None of the 5.8.8.x has worked for me so far up to and including 5.8.8.6 as BI just randomly shuts down with any of them. No biggie, since BIT starts it right back up. But, each time I've downgraded back to 5.8.7.11, which works very well (for me), any camera that is using another camera's Audio has the "Enable audio channel" unticked, so I need to go into each of them and re-tick it. Just a head's up...
Same problem with 5.8.8.latest. First time the entire PC locked up and I had to force a power off and restart. Seven and nine days later the PC restarted after running out of virtual memory - somewhere around 80 GB. Both time the committed memory was less than 12 GB and holding steady the night before. Looking at the log files a bunch of processes could not obtain more memory. When this started happening BI was using ~75GB. within an hour BI was using an additional 4-5GB. Very soon after the second warning message the PC restarted.
I have switched back to 5.8.7.11. Too soon to tell is this fixes the problem. Going to be away for a few weeks so I have no choice but to hope so.
Top
