- Mar 9, 2014
- 36,891
- 21,408
5.3.3 - September 30, 2020
When using dual-streaming, JPEG images will be created from the main-stream instead of
the sub-stream where possible. Rather than fully spooling up main-stream decoding, the
software uses the direct-to-disc pre-trigger frames buffer to synthesize these images. This
means you should specify at least enough pre-trigger time on the Record tab to span the
key-frame interval for your main-stream.
An optional parameter &jpeg=path has been added to both the &trigger and &flagalert web
server admin commands. This allows you to replace the alert image with one potentially
“marked up” by external analysis.
The RTSP server was updated to accommodate requirements of the Monocle portal for
viewing cameras on Echo Show.
