- Mar 9, 2014
- 36,891
- 21,408
5.2.0 - March 4, 2020
Although largely “under the hood,”significant changes made for this release justify a bump
in the minor version number.
Camera streaming code has been revised for performance and efficiency. By moving one
step “closer to the metal,” the goal here was to better support multiple high-bandwidth
cameras and to prepare for IPV6 connections. With a larger system, you should see modest
reductions in CPU demand as well. It’s still possible for the network receive buffer to
become overwhelmed if the CPU/GPU cannot keep up with decoding all frames in real-time
(when not using the limit decoding feature)—to better handle this we will be adding
support for dual-streaming main and sub-streams.
Web server code has been revised for performance and efficiency. By removing layers of
abstraction, the web server should be faster and more reliable overall.
The software will prompt for a user login when the “require admin run-as administrator”
has been unchecked on the Settings/Startup page, now even when BlueIris.exe is run with
Windows administrator rights.
Updates for Sentry Smart Alerts API 2 preparing for facial recognition
