5.1.0 - February 16, 2020
fenderman
Staff member
Mar 9, 2014
36,891
21,408
A clip “export” command has been added to the JSON web services. This allows the UI3 to
offer a more powerful experience managing video downloads.
Once the evaluation period is over, the software will continue to run as a “viewer only.”
This allows BVR files to be opened and exported without a software license.
Copy and Paste buttons have been added to the motion detector mask editing window.
Masks may only be pasted when the target image size matches the copied image size.
Using the Shield icon or camera “pause” commands you may now cancel a camera alert in-
progress.
"Copy and Paste buttons have been added to the motion detector mask editing window. "
Awesome new feature!!!
Hello,
Currently, I am on 4.8x version It is running fine and I don't use the web UI. Should I upgrade and if so, what are the benefits / improvements that justify it. I am curious if there are any improvements to core...
Also, is it a full purchase from 4.8x or how should I go about this?
Lastly, If I upgrade, I would like to retain camera / BI settings and blow out the whole install and start fresh. I assume that would require a (new?) License Key..?
Thanks!
Hello,
Thanks!
See the blue Iris upgrade guide in the wiki.
