4MP 1/1.8” CMOS vs 8MP 1/2.7” CMOS — which is better?
Macak11
Aug 13, 2025
12
Serbia
I’m comparing two Dahua models: IPC-HDW2449T-S-PRO (4MP 1/1.8” CMOS) and HDW2849TM-S-IL (8MP 1/2.7” CMOS).
Which is generally better — lower resolution with a larger sensor, or higher resolution with a smaller sensor?
I’m specifically asking about these two models since they’re in a similar price range, but if you have suggestions for something better, feel free to share.
Forget both and get the 3449 Pro for same $
always bigger sensor.. and lower resolution...
in both cases pixel size is bigger = more sensible to the light...
if you look at cams to buy for now only WizColor cams (2449-PRO, 3449-PRO, 5459-PRO) plus older 5442 are way to go...
Thanks again for the info, Steve.
8MP vs 4MP
The more MP the bigger the sensor you need to get the same light
Choose a camera with resolution to sensor ratio in the GREEN:
Most cheap cameras do reasonably well in full daylight, however most Bad things (tm) happen at night
What you recommend up to 150e ≈ 175usd
TIOC-PRO 3449
fixed 5442
turret EmpireTech IPC-T54IR-AS-S3 1/1.8" CMOS 4MP IR Fixed-focal Turret Netwo
varifocal 5442
This thread is used as the go to for the new person here outlining the commonly recommended cameras (along with Amazon links) based on distance to IDENTIFY that represent the overall best value/best bang for the buck in terms of price and performance day and night. It might be a 2MP camera in some instances. Many here feel 4MP is the current sweet spot for these cameras.
The Importance of Focal Length over MP in camera selection
And coupled with that thread is this great thread which will show why all of the same 2.8 or 3.6mm cameras is the wrong choice (these are the common focal lengths consumer brands sell):
i-want-2-8mm-cameras-everywhere-to-see-everything-this-is-why-you-need-specific-fovs-with-purposeful-focal-lengths.70053/
We would encourage you to look at those threads in detail.
It will probably raise more questions than answers LOL
W
What about daylight?
No worries....get good pix with motion at night, good daytime pix with motion is easily achieved.
In most instances, you want to get a camera that will perform at your location for the worse situation, which for most of us is at night when it is dark and there is little to no light. If a camera performs at night, it is easier to tweak settings to make it work during the day than it is the other way around.
To further understand the importance of MP/sensor ratio, use a window on your house for example. Which one is clearer to look thru - the one with a screen or one without? The more holes a screen is produced with, the more material there is as well.
These sensors are small and we need to get as much light to them as possible.
An analogy to try to understand why cameras need so much more light - let's look at an 8MP camera and this 8MP needs at least four times the amount of light as a 2MP for the same sensor. The sensor size is the same in each camera, but when you spread the "screen" of 8MP worth of pixel holes across the same sensor, it now has 4 times the holes, but also 4 times the "screen material" than the 2MP.
Kind of hard to explain, but lets try to use a window screen as an analogy - take a window where the opening is fixed - that is the sensor - you add a screen to it (that represents 2MP) and looking out through the screen is a little darker outside because of the screen material. Now replace that screen with one that has four times the amount of holes (now it represents 8MP) and it will be darker looking through it because (while the resolution would be better) there is a lot more screen material.
So if your house is like most where the top pane is glass with no screen and the bottom half is window with the screen and you see something outside during the daytime - do you sit down to look out through the screen or do you stand up to look a the object through the window with no screen?
And that is accentuated even more at night time. Look out your window with and without the screen and it will be darker looking through the screen than without it. If you are looking out your window to see the stars or the moon, do you look out the part of the window with the screen, or the upper portion without the screen material?
Now obviously as it relates to a camera, you need to balance the amount of pixel holes with the screen material - too few holes (and thus less screen material) and the resolution suffers, and too many holes (and thus more screen material) and the more light that is needed.
Look at a window screen and available meshes. The actual window opening does not change size, so that is the sensor. The screen material is the "pixel screen" that makes up the MP. Which one of these is going to let more light thru?
So if you are taking a 22 mesh screen and trying to get the same amount of brightness thru into the house as the 4 or 14 mesh screen, it will need A LOT more light.
A close comparison would be the 22 mesh screen is an 8MP and the 14 mesh is a 4MP. So if you have the same amount of light going thru a 14 mesh screen as you do a 22 mesh screen, it will be darker for the 22 mesh screen and any parameter adjustment you do to brighten it (gain, iris, brightness) will add more noise.
….My wife now quite certain I’ve lost it as I tape different mesh size screens to the bathroom door while shining flashlights through it ….
And before it is asked LOL....
So some people say "Hey I will just downrez the 8MP camera to a 4MP camera" and nope, downrezing a camera does not work - It is still using the 8 million pixels - the camera doesn't change the "pixel resolution screen" on the camera when you go from 8MP to 4MP. The sensor still needs 2 times the light going from 8MP to 4MP, so the native 4MP camera will result in a better image at night. The firmware will make some algorithm attempt at downrezing it, but it could be a complete crap image or a somewhat usable image, but if there is a concern that the 8MP isn't performing or wouldn't perform well at night, then it is better to go with the 4MP.
This is from the Dahua 49225 (2MP on 1/2.8" sensor) versus 49425 (4MP on the same 1/2.8" sensor)
The 49225 is a 2MP PTZ on the 1/2.8" sensor. It deems it has enough light at a 1/60 shutter so it stays in color:
Here is the 49425, which is the same camera as the 49225 except is a 4MP on the same 1/2.8" sensor as the 49225.
Here is the first big issue you see with a double the resolution on the same size sensor - It deems that it does not have enough light at a 1/60 shutter so it goes to B/W with Infrared:
As you see above, I have a 4MP and 2MP on the same 1/2.8" sensor and the picture quality is quite different between the two and the 2MP kicks it's butt at night.
My 2MP cameras outperform my neighbors 4K (8MP) cameras....why....because they are both on the same size sensor.
When we had a thief come thru here and get into a lot of cars, the police couldn't use one video or photo from anyone's system but mine. Not even my other neighbors $1,300 8MP system provided useful info - the cams just didn't cut it at night.
My neighbor tried the "I will just downrez the 8MP to 2MP" and the image was a soft dark mess.
His system wasn't even a year old and after that event has started replacing with cameras based on my recommendation and seeing my results. He is still shocked a 2MP camera performs better than his 4k cameras and he cannot figure out why downrezing from 8MP to 2MP doesn't work properly... It is all about the amount of light needed and getting the right camera for the right location and downrezing doesn't change the physics of the camera.
But for kicks, let me downrez my 4MP to 2MP...
The first thing you notice is that downrezing the 4MP 49425 down to a 2MP doesn't result in the camera being able to run color like the native 2MP 49225 as the sensor still doesn't see enough light to run in color because the 4MP "pixel screen" simply isn't letting enough light get into the optics of the sensor.
That is a big deal with low light conditions and why you want to go with a native resolution and preferably a camera on the ideal MP/sensor ratio that is talked about here often. The native resolution may be able to be in color, but the higher resolution on the same size sensor probably won't with low light conditions.
Then in this case, you can see that the 4MP was struggling to even give definition compared to the 2MP. It is wet out so the rain reflections is wreaking havoc with the infrared and focus.
So when I downrezed but kept the bitrate the same, it still looks like a soft mess. Even if there is less noise in this instance, it still doesn't look as good as the native.
As always YMMV and I am sure the newer cameras are improved over when this camera came out, but even so I don't think we see a higher MP downrez come close to the performance of a native MP on the same size sensor because the higher MP just isn't letting enough light into the optics as the lower MP on the same size sensor.
And the less light that is available, the bigger the difference one will see. Personally, for me the difference between being able to run it in color versus B/W is enough of a reason to go with the camera that is on the ideal MP/sensor ratio talked about here so much.
