- Sep 25, 2017
- 3,071
- 3,984
Hi,
Need some help as pulling my hair out.
One of my 4kt's went bad so Andy replaced it. I've put the new camera in place but I cannot contact it.
So far I've tried:
1. Searching in the CONFIG APP - nothing found under default IP / password initialised or otherwise (192.168.1.108 - admin - blank password)
2. I've tried moving it from the 2nd LAN card to the primary LAN card on the BI server so it can face the internet / pc better, no effect. Still not found.
3. I'm able to rule out the cable to the remote POE switch as my other camera is functioning fine and this cable being a connector pc to the poe is common
4. I've tested the LAN cable from the poe switch to the new camera using a network tester - all 8 connectors show green in the correct order on the test pulses - less than 1 metre long in any event
5. I've tried switching the LAN plug into a different port in the POE switch, no change
6. I've tried plugging the new camera into the poe port used by the working camera after removing it, no change and working camera works in that port when switched back
7. I've tried searching under the old cameras altered IP & password just in case it somehow got caried across in the switch (unmanaged so it shouldn't have), no connection
8. I've tried resetting the 2nd LAN card, no change
9. I've tried rebooting the BI PC, no change
10. Looking out the window tonight, the new cameras led lights are lit so poe supplying power but camera still unconatactable by both IE and CONFIG App.
11. I've tried running a range of IP's in the CONFIG app eg 192.168.1.1 - 255 and nothing found either
The config app finds my working initialised camera straight away on it's ip address but I cannot contact the new un-initialised camera.
What am I missing?
So far I've tried:
What am I missing?
