- Sep 25, 2017
- 2,875
- 3,758
WIth the 4kt and BI when the recording swicthes between Sub Stream and Mainstream on a trigger the picture quality is being affected.
This camera is set up with custom BLC enabled on the background because without it is overblown. When on substream the picture looks fine, When the camera is triggered however, the backlit area and other areas affected by that become oversharpened and like a painting with splodges rather than clear definition. When the camera switches back to substream , the issue disappears. I've noticed that same effect when doing anything that causes it to switch to mainstream.
I have a video clip here, recorded from my phone because I don't have a video editing program on my BI PC, so apologies for the quality. You can see the change over around 10 secs.
The video starts of in triggered mode (someone has walked through and triggered the mainstream), and then around 10 seconds it reverts to sub stream. Watch the bakground houses and bushes and you'll see the switch between stream and the dramatic improvement when it switches to sub stream at 10 secs:
Best watched full screen.
Obviously if this is a firmware issue, Dahua need to look at this. If not, I need to speak to the guys at BI. However, it seems more likely to be firmware in my opinion.
